MLudes
Sponsor Astronomie.de
Eine neue hochwertigster astronomischer Okulare von NIKON, von NIKON nicht für den Export nach Europa freigegeben !
APM ist authorisierter Importeur für Europa durch den Japanischen Verteiler , somit erhalten Sie bei uns die japanische NIKON Garantie .
Deutsche Übersetzuung folgt anfang der Woche, dies nur als Vorab Info.
NIKON NAV SW Series (visual) Eyepiece Specs
Item f/l Field of View Eye relief Lens Design Size (mm) Weight (gr.) Retail Price in Euro incl. 19% VAT
NAV 5SW 5mm 72 degree 18mm 6 group / 8 lens 56.5 x 91 300 Euro 545
NAV 7SW 7mm 72 degree 17mm 6 group / 8 lens 56.5 x 78 290 Euro 545
NAV 10SW 10mm 72 degree 19mm 6 group / 8 lens 56.5 x 79 300 Euro 545
NAV 14SW 14mm 72 degree 18mm 5 group / 7 lens 56.5 x 77.5 275 Euro 545
NAV 17.5SW 17.5mm 72 degree 26mm 5 group / 8 lens 56.5 x 94.5 365 Euro 645
EiC-16
converter lens Specifically optimized for Nikon NAV SWs, the EiC-16 provides a 1.6X tele-extension for the NAV SWs, with even more enhanced field curvature and astigamitism suppresion. Can also be used with other makers eyepieces, 1.25" size Euro 320
Nikon NAV 10SW delivery is scheduled for March 2010. All others in stock and ready for immediate shipment
Übersetzung insd deutsche erfolgt anfang der Woche, daher vorab mal den original NIKON Japan Werbetext
NIKON NAV SW Series Astronomical Eyepieces
Hot off their optical benches, Nikon commemorated the International Year of Astronomy 2009 with the birth of their brand new and long awaited NAV-SW series eyepieces. Manufactured in five different focal lengths, all are now currently available except the NAV 10SW, which is scheduled to be released in March 2010.
Nikon NAV SWs, based on their excellent eyepieces for Nikon spotting scopes, have evolved to meet the requirements of high level astronomical observation, with the deepest attention devoted to exquisite rendition of astronomical point sources of light, while also taking a chapter for the digiscope design world, which demands flat fields and sharp images right to the very edge of the field of view. The NAV SW design emphasizes suppresion of field curvature and all astigmatism to bring about the maximum improvement in edge of field fidelity wthout sacrificing the quality of the image at the central of field.
Nikon NAV SWs are all 72 degree FOV eyepieces installed inside compact 1.25" size eyepiece bodies. The comfortable eye relief specs for each eyepiece are designed to also harmonize with the optical performance of that eyepiece. Also, removal of exit pupil aberrations virtually eliminates any instance of kidney bean blackout effect, regardless of where the eye is placed during observation. The excellent color balance of the NAV SWs was derived through rigorous testing of this optical parameter on terrestrial objects, insuring the highest degree of planetary and lunar color rendition. Multicoatings on every optical surface make sure that these images are also as bright and otherwise distortion free as possible.
The Nikon NAV SW exterior design is somewhat reminiscent of the tried and true Nikkor lens design, with an attractive, high quality appearance, and rollets located around the entire circumference making the eyepieces easy and sure to grip even in darkness, or with gloved hands. A flexible silicone rubber eye shield on the top of the eyepiece helps block streets lights and other annoying sources of light pollution, especially a help when viewing sensitive planetary and lunar surface details at high magnifications. NAV SW eyepiece also incorporate a unique phosphorescent logo that glows ever so slightly to help make seeing the eyepieces (or finding them) in the dark just a little easier.
Nikon NAV SWs moisture resistant design will provide long years of constant and worry free service and viewing pleasure to discriminating astronomers in any observing environment worldwide.
The combination of the ideal optical qualities of a flat and wide 72 degree FOV that is sharp from edge to edge, excellent color rendition, comfortable eye relief intelligently designed to harmonzie specifically with each eyepiece, a beautiful and compact body design, highest quality Japanese glass, multi-coatings and exterior materials, and a good selection of focal lengths, makes the Nikon NAV SWs a true and new winner in the ever expanding world of 21 century astronomy.
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/42898_2.jpg
bilder.apm-telescopes.de/images/artikel/73070_3.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/42898_1.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/97488_1.jpg Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/73070_1.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/58643_1.jpg Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_1.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_4.jpg Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_5.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_6.jpg Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_7.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_8.jpg Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_9.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_10.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_11.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_12.jpg
Lieferzeiten : ca. 1-2 Wochen, nur das 10 mm kommt erst später im März
EiC-16
