Ein 100 Meter Teleskop auf dem Mond? | Astronomie.de - Der Treffpunkt für Astronomie
Die Papers zum Teleskop auf dem Mond habe ich noch nicht gelesen, aber das erste über das exisitierende 6m Instrument ist interessant und lesenswer. In der Größe scheint das gut zu funktionieren und Erfahrungen und praktischen Lösungen haben sie ja schon.
Grüße, Martin
P_E_T_E_R
Bevor die Leute bei Boing sich mit trivialeren Problemen wie abstürzenden Flugzeugen befassen mussten, haben sie sich dort u.a. noch Gedanken gemacht, wie man große Spiegel mit reflektierenden Oberflächen aus flüssigem Metall als frei schwebende Strukturen im schwerelosen Raum einsetzen könnte:
Space Based Liquid Ring Mirror Telescope (SBLRMT)
There are several advantages and few disadvantages, of deploying a large Space Based Liquid Ring Mirror Telescope (SBLRMT). The two most significant problems facing large optics in space are weight and wavefront control. Liquid Mirrors go a long way to mitigating these two problems. They provide light (7kg/m²) primary mirror and 10 nanometer figure control passively. There are technology issues, but no physics show stoppers. Ground based 2-3 meter liquid mirrors routinely achieve 10 nanometer surface control.
A liquid Ring Mirror works by spinning liquid mercury under the acceleration of gravity to produce a parabolic surface. This great performance is achieved without the expense of polishing or the complication of advanced metrology systems, and Liquid Mirrors are thermally stable. Unfortunate restriction of ground based mirrors is that they can only look straight up. Space based mirrors, however, don’t suffer this restriction. Since there is no gravity in space thrust can work as a substitute for gravity as the source of acceleration. Additionally, spinning any object in space is relatively easy without the need for bearings, which only add vibration. This paper will discuss the benefits of a large liquid mirror in space as well as address some of the apparent issues.
Der Spiegel wird für die Dauer der Beobachtung gleichförmig in Richtung des zu beobachtenden Objekts beschleunigt und dabei um die Bewegungsrichtung rotiert. Damit entfällt die gravierende Restriktion eines Zenitteleskops im Schwerefeld der Erde oder des Mondes!
