• Verschoben: Am 29.03.2020 wird in der Zeit von 20.00 bis 21.30 Uhr ein Update (Patchday) der Forensoftware eingespielt. In diesem Zeitraum wird das Forum in den Wartungsmodus versetzt. Vielen Dank für Euer Verständnis Euer Moderatorenteam
Hubble's Southern Crab
P_E_T_E_R
Hubble Celebrates 29th Anniversary with a Colorful Look at the Southern Crab Nebula
The nebula, officially known as Hen 2-104, is located several thousand light-years from Earth in the southern hemisphere constellation of Centaurus. It appears to have two nested hourglass-shaped structures that were sculpted by a whirling pair of stars in a binary system. The duo consists of an aging red giant star and a burned-out star, a white dwarf. The red giant is shedding its outer layers. Some of this ejected material is attracted by the gravity of the companion white dwarf.
The object was first reported in the late 1960s, but was assumed to be an ordinary star. In 1989, astronomers used the European Southern Observatory's La Silla Observatory in Chile to photograph a roughly crab-shaped extended nebula, formed by symmetrical bubbles.
These early observations only showed the outer hourglass emanating from a bright central region. Hubble photographed the Southern Crab in 1999 to reveal complicated nested structures. These latest images were taken in March 2019 with a wide set of color filters on Hubble's newest, sharpest detector, Wide Field Camera 3. This image is a composite of observations taken in various colors of light that correspond to the glowing gases in the nebula. Red is sulfur, green is hydrogen, orange is nitrogen, and blue is oxygen.
Zooming in on the Southern Crab Nebula
Credit: NASA/ESA/STScI
104094
104095
