P_E_T_E_R
Vielleicht gar nicht so dumm, bei längerem Aufenthalt da Schutz zu suchen:
Lunar Pits Harbor Comfortable Temperatures
The pits, and caves to which they may lead, would make thermally stable sites for lunar exploration compared to areas at the Moon’s surface, which heat up to 127 C during the day and cool to minus 173 C at night
Pits were first discovered on the Moon in 2009, and since then, scientists have wondered if they led to caves that could be explored or used as shelters. The pits or caves would also offer some protection from cosmic rays, solar radiation and micrometeorites.
About 16 of the more than 200 pits are probably collapsed lava tubes. Two of the most prominent pits have visible overhangs that clearly lead to caves or voids, and there is strong evidence that another’s overhang may also lead to a large cave.
The results [of thermal measurements] revealed that temperatures within the permanently shadowed reaches of the pit fluctuate only slightly throughout the lunar day, remaining at around 17 C. If a cave extends from the bottom of the pit, as images taken by LRO’s Lunar Reconnaissance Orbiter Camera suggest, it too would have this relatively comfortable temperature.
This is a spectacular high-Sun view of the Mare Tranquillitatis pit crater revealing boulders on an otherwise smooth floor.
This image from LRO's Narrow Angle Camera is 400 meters wide, north is up.
Credits: NASA/Goddard/Arizona State University
