<?xml version="1.0" encoding="UTF-8"?>
<VOTABLE version="1.1" xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance"
xmlns="
http://www.ivoa.net/xml/VOTable/v1.1"
xsi:schemaLocation="
http://www.ivoa.net/xml/VOTable/v1.1 http://www.ivoa.net/xml/VOTable/v1.1">
<DESCRIPTION>
VizieR Astronomical Server: webviz.u-strasbg.fr 2008-09-16T17:08:05
Explanations and Statistics of UCDs: See LINK below
In case of problem, please report to:
question@simbad.u-strasbg.fr
</DESCRIPTION>
<!-- VOTable description at
http://www.ivoa.net/Documents/latest/VOT.html -->
<DEFINITIONS>
<COOSYS ID="J2000" system="eq_FK5" equinox="J2000"/>
</DEFINITIONS>
<!-- Parameters used for the Query:
-to=4
-from=-3
-this=-3
-out.max=unlimited
-out.form=VOTable
-order=I
-c=
-c.eq=J2000
-oc.form=dec
-c.r= 2
-c.u=arcmin
-c.geom=r
-out.add=_r
-out.add=_RA*-c.eq,_DE*-c.eq
-out.add=_RAJ,_DEJ
-source=V/50/catalog
-out=SAO
SAO=!=
-out=Vmag
-sort=Vmag
Vmag=<=10
-out=SpType
SpType=
-meta.ucd=u
-file=.
-meta=0
-meta.foot=1
<INFO ID="Ref" name="-ref" value="VOTx16884"/>
<INFO ID="MaxTuples" name="-out.max" value="50000"/>
<RESOURCE ID="yCat_5050" name="V/50">
<DESCRIPTION>Bright Star Catalogue, 5th Revised Ed. (Hoffleit+, 1991)</DESCRIPTION>
<COOSYS ID="J2000_2000.000" system="eq_FK5" equinox="J2000" epoch="2000.000"/>
<TABLE ID="V_50_catalog" name="V/50/catalog">
<DESCRIPTION>The main part of the Catalogue</DESCRIPTION>
<!-- RowName: ${HR} -->
<!-- Now comes the definition of each field -->
<FIELD name="_RAJ2000" ucd="pos.eq.ra;meta.main" ref="J2000" datatype="double" width="8" precision="4" unit="deg"><!-- ucd="POS_EQ_RA_MAIN" -->
<DESCRIPTION>Right ascension (FK5) Equinox=J2000.0 Epoch=J2000.000, proper motions taken into account (computed by VizieR, not part of the original data)</DESCRIPTION>
</FIELD>
<FIELD name="_DEJ2000" ucd="pos.eq.dec;meta.main" ref="J2000" datatype="double" width="8" precision="4" unit="deg"><!-- ucd="POS_EQ_DEC_MAIN" -->
<DESCRIPTION>Declination (FK5) Equinox=J2000.0 Epoch=J2000.000, proper motions taken into account (computed by VizieR, not part of the original data)</DESCRIPTION>
</FIELD>
<FIELD name="SAO" ucd="meta.id" datatype="int" width="6"><!-- ucd="ID_ALTERNATIVE" -->
<DESCRIPTION>[1/258997]? SAO Catalog Number</DESCRIPTION>
</FIELD>
<FIELD name="Vmag" ucd="phot.mag;em.opt.V" datatype="float" width="5" precision="2" unit="mag"><!-- ucd="PHOT_JHN_V" -->
<DESCRIPTION>?Visual magnitude (1)</DESCRIPTION>
</FIELD>
<FIELD name="SpType" ucd="src.spType" datatype="char" arraysize="20*"><!-- ucd="SPECT_TYPE_GENERAL" -->
<DESCRIPTION>Spectral type</DESCRIPTION>
</FIELD>
<DATA> <TABLEDATA>
<TR><TD>101.2871</TD><TD>-16.7161</TD><TD>151881</TD><TD>-1.46</TD><TD> A1Vm</TD></TR>
<TR><TD>095.9879</TD><TD>-52.6958</TD><TD>234480</TD><TD>-0.72</TD><TD> F0II</TD></TR>
<TR><TD>213.9154</TD><TD>+19.1825</TD><TD>100944</TD><TD>-0.04</TD><TD> K1.5IIIFe-0.5</TD></TR>
<TR><TD>219.8996</TD><TD>-60.8353</TD><TD>252838</TD><TD>-0.01</TD><TD> G2V</TD></TR>
<TR><TD>279.2346</TD><TD>+38.7836</TD><TD>67174</TD><TD>0.03</TD><TD> A0Va</TD></TR>
<TR><TD>079.1725</TD><TD>+45.9981</TD><TD>40186</TD><TD>0.08</TD><TD> G5IIIe+G0III</TD></TR>
<TR><TD>078.6346</TD><TD>-8.2017</TD><TD>131907</TD><TD>0.12</TD><TD> B8Ia:</TD></TR>
<TR><TD>114.8254</TD><TD>+5.2250</TD><TD>115756</TD><TD>0.38</TD><TD> F5IV-V</TD></TR>
<TR><TD>024.4287</TD><TD>-57.2367</TD><TD>232481</TD><TD>0.46</TD><TD> B3Vpe</TD></TR>
<TR><TD>088.7929</TD><TD>+7.4069</TD><TD>113271</TD><TD>0.50</TD><TD> M1-2Ia-Iab</TD></TR>
<TR><TD>210.9558</TD><TD>-60.3731</TD><TD>252582</TD><TD>0.61</TD><TD> B1III</TD></TR>
<TR><TD>297.6958</TD><TD>+8.8683</TD><TD>125122</TD><TD>0.77</TD><TD> A7V</TD></TR>
<TR><TD>068.9800</TD><TD>+16.5092</TD><TD>94027</TD><TD>0.85</TD><TD> K5+III</TD></TR>
<TR><TD>247.3517</TD><TD>-26.4319</TD><TD>184415</TD><TD>0.96</TD><TD> M1.5Iab-Ib+B4Ve</TD></TR>
<TR><TD>201.2983</TD><TD>-11.1614</TD><TD>157923</TD><TD>0.98</TD><TD> B1III-IV+B2V</TD></TR>
<TR><TD>116.3287</TD><TD>+28.0261</TD><TD>79666</TD><TD>1.14</TD><TD> K0IIIb</TD></TR>
<TR><TD>344.4129</TD><TD>-29.6222</TD><TD>191524</TD><TD>1.16</TD><TD> A3V</TD></TR>
