JSchmoll
JAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA !
<img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" /> <img src="/phpapps/ubbthreads/images/icons/smile.gif" alt="" />
Wo ist das Beruhigungsmittel - das kann nicht gesund sein ! Sorry, ich habe gerade einen Euphorieanfall ...
Zur Vorgeschichte: Ich hatte hier meine Leidensgeschichte ueber mein 244/904 mm - Projekt ("Juchuu, mein Spiegel ist fast fertig !") und das neue Auge fuer Sir William ("Projekt Strehl", 196/1070 mm) berichtet.
Nun habe ich ja immer schoen mit meiner am Kuechentisch gebastelten, einfachen Foucaultlampe gemessen - mit einer Regalstange zum Spiegelstaender verbunden weil ja ueberall Teppich liegt. Ich bekam nach Punktabtastung mit den verschiedenen Masken sehr gute Resultate (beim 10" nach langem "Leiden"), aber es ist ja nur Punktabtastung.
Nun, der Alumensch in London kann nicht nur Spiegel aluminisieren, sondern sie auch testen - als ich das hoerte bekam ich Ohren gross wie Radioteleskope, denn ich konnte beide Spiegel mangels Teleskope nicht am Stern verifizieren. Also ihm den Castorbehaelter mit den beiden Holzkisten zugeschickt - vorm Aluminisieren testen und wenn Gurke vorm Aluminisieren zurueck. Nun, der Test ist kein Interferogramm sondern ein Nulltest, offenbar in Autokollimation. Ausserdem gibt es einen Ronchitest.
Nun, ich schickte das Paket (bebeppert mit allerlei Aufklebern vonwegen FRAGILE, HIER OBEN, WEHE WENN und so weiter).
Panik1 dauerte eine knappe Woche. Dann war die Kiste drueben, Puh !
Panik2 dauerte bis eben - was wird der Test ergeben ? Erst sollte letzte Woche getestet werden - es kam keine Antwort. Nanu ? Spiegel runtergefallen ? So schlecht dass er verzweifelt versucht ein Bild zu bekommen ? Hmmmm ...
Eben dann die Antwort, die Ausloeser obigen Euphorieanfalls wurde ...
Dear Jurgen,
Sorry to keep you waiting. I have now looked at both of your mirrors and am very impressed.
With autocollimation and a knife-edge test, both mirrors null out with no discernable shadows- therefore guaranteed better than 1/8th wave. With autocollimation and 100 line per inch grating, the quality is confirmed. The lines expand as focal point is reached with no deviation from true ( i.e. keeping straight) right up to the edge and a fine diffraction line on the left hand side of both mirrors (light source is to the right) confirms there are no edge faults.
I am unable to test the middle 2" of any mirror, because of my test set-up, but that's of no concern.) We hope to be able to coat both mirrors for you on Thursday, but I may not be able to despatch until Friday.
[Uebersetzung fuer Nicht-Anglisten:
Entschuldigen Sie die Verzoegerung. Ich habe mir nun beide Spiegel angesehen und ich bin sehr beeindruckt.
Mit Autokollimation und Messerscheide zeigen beide Spiegel im Nulltest keine erkennbaren Schatten - somit sind sie garantiert besser als lambda/8 Wellenfront. In Autokollimation und mit einem 100 Linien/Zoll - Gitter bestaetigt sich diese Qualitaet - bis zum Rand ist keine Abweichung der geraden Linien erkennbar und eine feine Beugungskante auf der linken Seite beider Spiegel zeigt, dass es keine Randfehler [abgesunkene Kante] gibt.
Ich kann die mittleren 2" der Spiegel aus technischen Gruenden nicht vermessen, aber das macht nichts. Ich hoffe, wir koennen beide Spiegel am Donnerstag verspiegeln und freitags versenden.]
Dear Jurgen,
