Neu: NIKON NAV SW Series astro. Okulare
MLudes
Sponsor Astronomie.de
Eine neue hochwertigster astronomischer Okulare von NIKON, von NIKON nicht für den Export nach Europa freigegeben !
APM ist authorisierter Importeur für Europa durch den Japanischen Verteiler , somit erhalten Sie bei uns die japanische NIKON Garantie .
Deutsche Übersetzuung folgt anfang der Woche, dies nur als Vorab Info.
NIKON NAV SW Series (visual) Eyepiece Specs
Item f/l Field of View Eye relief Lens Design Size (mm) Weight (gr.) Retail Price in Euro incl. 19% VAT
NAV 5SW 5mm 72 degree 18mm 6 group / 8 lens 56.5 x 91 300 Euro 545
NAV 7SW 7mm 72 degree 17mm 6 group / 8 lens 56.5 x 78 290 Euro 545
NAV 10SW 10mm 72 degree 19mm 6 group / 8 lens 56.5 x 79 300 Euro 545
NAV 14SW 14mm 72 degree 18mm 5 group / 7 lens 56.5 x 77.5 275 Euro 545
NAV 17.5SW 17.5mm 72 degree 26mm 5 group / 8 lens 56.5 x 94.5 365 Euro 645
EiC-16
converter lens Specifically optimized for Nikon NAV SWs, the EiC-16 provides a 1.6X tele-extension for the NAV SWs, with even more enhanced field curvature and astigamitism suppresion. Can also be used with other makers eyepieces, 1.25" size Euro 320
Nikon NAV 10SW delivery is scheduled for March 2010. All others in stock and ready for immediate shipment
Übersetzung insd deutsche erfolgt anfang der Woche, daher vorab mal den original NIKON Japan Werbetext
NIKON NAV SW Series Astronomical Eyepieces
Hot off their optical benches, Nikon commemorated the International Year of Astronomy 2009 with the birth of their brand new and long awaited NAV-SW series eyepieces. Manufactured in five different focal lengths, all are now currently available except the NAV 10SW, which is scheduled to be released in March 2010.
Nikon NAV SWs, based on their excellent eyepieces for Nikon spotting scopes, have evolved to meet the requirements of high level astronomical observation, with the deepest attention devoted to exquisite rendition of astronomical point sources of light, while also taking a chapter for the digiscope design world, which demands flat fields and sharp images right to the very edge of the field of view. The NAV SW design emphasizes suppresion of field curvature and all astigmatism to bring about the maximum improvement in edge of field fidelity wthout sacrificing the quality of the image at the central of field.
Nikon NAV SWs are all 72 degree FOV eyepieces installed inside compact 1.25" size eyepiece bodies. The comfortable eye relief specs for each eyepiece are designed to also harmonize with the optical performance of that eyepiece. Also, removal of exit pupil aberrations virtually eliminates any instance of kidney bean blackout effect, regardless of where the eye is placed during observation. The excellent color balance of the NAV SWs was derived through rigorous testing of this optical parameter on terrestrial objects, insuring the highest degree of planetary and lunar color rendition. Multicoatings on every optical surface make sure that these images are also as bright and otherwise distortion free as possible.
The Nikon NAV SW exterior design is somewhat reminiscent of the tried and true Nikkor lens design, with an attractive, high quality appearance, and rollets located around the entire circumference making the eyepieces easy and sure to grip even in darkness, or with gloved hands. A flexible silicone rubber eye shield on the top of the eyepiece helps block streets lights and other annoying sources of light pollution, especially a help when viewing sensitive planetary and lunar surface details at high magnifications. NAV SW eyepiece also incorporate a unique phosphorescent logo that glows ever so slightly to help make seeing the eyepieces (or finding them) in the dark just a little easier.
Nikon NAV SWs moisture resistant design will provide long years of constant and worry free service and viewing pleasure to discriminating astronomers in any observing environment worldwide.
The combination of the ideal optical qualities of a flat and wide 72 degree FOV that is sharp from edge to edge, excellent color rendition, comfortable eye relief intelligently designed to harmonzie specifically with each eyepiece, a beautiful and compact body design, highest quality Japanese glass, multi-coatings and exterior materials, and a good selection of focal lengths, makes the Nikon NAV SWs a true and new winner in the ever expanding world of 21 century astronomy.
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/42898_2.jpg
bilder.apm-telescopes.de/images/artikel/73070_3.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/42898_1.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/97488_1.jpg Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/73070_1.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/58643_1.jpg Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_1.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_4.jpg Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_5.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_6.jpg Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_7.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_8.jpg Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_9.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_10.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_11.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/64670_12.jpg
Lieferzeiten : ca. 1-2 Wochen, nur das 10 mm kommt erst später im März
Hallo Markus,
in der Beschreibung wird von einem "comfortable eye relief" gesprochen. Wie groß ist denn dieser? Meist ist der nicht so besonders, wenn keine direkte Angabe vorhanden ist. Wäre besonders für einen Vergleich mit den Pentax XW interessant.
CS,
Update: Hab die Angaben auf Eurer Seite gefunden. Ließt sich ja recht gut.
Hallo Peter
danke für die Nachfrage, geht in der Auflistung etwas unter, die saubere tabelle kannst du hier einsehen http://www.apm-telescopes.de/nikon-nav-sw-5mm-okular_proinfo_42898.html
Die ersten User in USA beschreiben, das das Einblickverhalten noch etwas angenehmer sein soll als beim XW
Ich habe die NIKON Okulare beim ITV und ATT dabei, dann kann sich jeder selbst einen Eindruck machen, bin selbst sehr gespannt , in ein paar tagen dürfte ich die ersten live in der Hand halten
Danke für den Link (habe ich kurz davor auch entdeckt). Also besonders das 17,5 wäre mit 26mm Augenabstand und 56,6mm Durchmesser ja wirklich gigantisch fürs Bino.
CS,
Hallo Leute,
heute endlich sind die Okulare eingetroffen. Nach 5 Tagen Sonnenschein ist es prompt heute bewölkt, sodaß sich das First Light unterm Himmel wohl verschieben muß.
Das 10 m und Barlow fehlen noch, dauert noch ca. 8 bis 10 Tage zum Eintreffen.
Vorab erst mal ein paar Infos:
Die beidseitigen Deckel sind was neues , aber schon irgentwie Praktisch
Die Beschriftungsplatte hat entgegen der englischen Beschreibungs phosporisierendes und leuchtet NICHT. Wir haben dies nun gleich auf unserer Homepage geändert. Wir haben gleichzeitig ein Mail nach Japan geschickt , zu unserem Lieferanten, er wird nun NIKON kontaktieren um zu erfragen ob dies nun doch nicht so gemacht wird oder vielleicht erst in Zukunft.
Die Okulare haben keine Sicherungsnut an der 1.25" Steckhülse mit Filtergewinde, was ich persönlich als großen Vorteil bei heutigen Klemmringen sehe. Jedoch gibt es eine minimal konisch zulaufende Verjüngung zum Gehäuse von ca 1/10 mm. Nochwas zur Vergütung: Beim 5 mm, 7 mm und 17.5 mm haben wir eine überwiegend grüne Vergütung, das 14 mm fällt aus der Reihe und hat eher eine Goldvergütung, ähnlich dem neuen Leica Zoom
Die Techn. Spezifikationen haben wir überprüft und weichen von den NIKON Angaben etwas ab, die richtigen Spez. sind
Durchmesser Augenlinse
beim 17.5 mm > 35 mm
beim 14 mm > 25 mm
beim 7 mm > 25 mm
beim 5 mm > 25 mm
Durchmesser der Fledblenden :
beim 17.5 mm : 24 mm kleinstes Scheinbares Gesichtsfeld , gleichgroße wie beim Panoptik 24 mm ( 68° )
beim 14 mm : 18 mm gleiches scheinbares Gesichtsfeld wie 7 mm , gleichgroß wie beim alten NIKON 7 mm (60x/75) mit 72° angegeben
beim 7 mm : 9 mm gleiches Scheinbares Gesichtsfeld with 14 mm , gleichgroß wie beim alten NIKON 7 mm (60x/75) mit 72° angegeben
beim 5 mm : 10 mm größtes scheinbares Gedsichtsfeld, größer wie beim alten NIKON 7 mm (60x/75) mit 72° angegeben , schätze auf 74°
Scheinbares Gesichtsfeld :
beim 17.5 mm > 72°
beim 14 mm > 68°
beim 7 mm > 72°
beim 5 mm > 74°
Durchmesser Gehause incl. abschraubbarer Augenmuschel
beim 17.5 mm > 57 mm
beim 14 mm > 57 mm
beim 7 mm > 57 mm
beim 5 mm > 57 mm
Durchmesser Gehause ohne abschraubbarer Augenmuschel
beim 17.5 mm > 51 mm
beim 14 mm > 53 mm
beim 7 mm > 53 mm
beim 5 mm > 54 mm
Gewicht incl. Augenmuschel
beim 17.5 mm > 365 gram
beim 14 mm > 269 gram
beim 7 mm > 286 gram
beim 5 mm > 300 gram
die Vermessung vom 10 mm und der Barlow erfolgt sobald ich diese in den Händen habe
Wir ändern morgen die Specs auf unserer Webseite ab
so nächste News.
1, ich habe mir diese Feldblendengeschichte nochmals angeschaut , da mir das beim 5 mm und 7 mm komisch vorkam. Das 5 mm hat eine größere Eingangslinse , aber gegens Licht haltend, sieht man das die Feldblende innsénsitzend doch kleiner ist als beim 7 mm, das nur zur Korrektur meiner Angaben.
First Light Test :
- Seeing ca. 5/10
- ca. 4 mag Himmel
- langsame Wolken kommen und gehen.
- Objekte : Mars , Orion und Umgebung
Mein persönlicher Subjektiver Eindruck :
2, komme eben rein vom Spechteln. Habe meinen Starmaster 24"F/4.3 Dobson eingesetzt , einmal ohne Tele Vue Paracorr ( Komakorrektor) und einmal mit sowie einen Takahashi TSA Apo 120 mm F/7.
Das NIKON 5 mm und 7 mm sind hervorragend Randkorregiert ( dies war mir früher schon beim alten NIKON 7 mm 72" -ED Spotter 60x/75x aufgefallen , Randschärfer im Dob als Nagler ) , Randscharf mit und ohne Paracorr . Auch im TSA knackscharf bis zum Rand. Das 5 mm hat eine absolut perfekt Streulichtkontrolle. Das 7 mm im Dobson ebenfalls, aber komischerweise blinzelt im TSA ein minialer Lichteinfall richtung Feld, wenn man Mars oder Sirius durch die Feldblende gerade so abdeckt. Dies ist weder beim 5 mm, noch beim 14 mm noch beim 17.5 mm der Fall.
Das 14 mm und 17.5 mm sind im Dobson mit Paracor ausgezeichnet, wenn auch nicht 100% perfekt Randscharf , ohne Paracorr dagegen haben Sie beide Probleme mit F/4.3 Koma eines 24"ers und zeichnen nur ca. 75 bis 80 % des Feldes scharf.
Im TSA 120 haben das 14 mm und 17 mm leichten aber dennoch sichtbaren Randastigmatimus.
Aufallend bei allen 4 Okulare ist der extrem angenehme Einblick , egal wie man reinschaut , das Bild ist immer voll da, kenne ich so eigentlich nur vom Leitz 30 mm 88°.
Hält man alle 4 Okulare umgedreht, durch die Eingangslinse schauend über eine Kante und lässt die kante zum Rand des Feldes wandern, bleibt diese Kante schnurgerade , auch hier hat NIKON nicht übertrieben.
Sehr angehm im Betrieb sind die beiden Okulardeckel die per 2 Gummibändchen miteinander verbunden sind, sowas geht im Gegensatz zu normalen Deckeln eher nicht verloren und rollt auch nicht weg.
Hochinteressant dürften diese NIKON OKulare für Binokulare beobachter sein , wegen Ihrem geringem Durchmesser aber auch wegen Ihrem extrem angenehmen Einblick.
Ich werde diese Okulare sowohl beim ATT wie auch beim ITV dabei haben.
Bei ernsthaftem Interesse leihen wir das eine oder andere gerne auch mal zum Test aus.
Wir haben nun endlich auch das NAV-10SW Okular erhalten und letzte Nacht schon getestet, auch hier beträgt das geishctsfeld wie beim 5er 74° und die Korrektur ist gleich gut wie beim 5er, damit sind das 5er und das 10er die besten aus der Reihe.
Die 1.6 x Barlow von NIKON ist ebenfalls eingetroffen , hier die Eckdaten
Nikon EiC-16 Barlow Linse 1.25"
Speziell für die Nikon NAV SW Okulare optimierte Barlow Linse. Sie verlängert die Brennweite um den Faktor 1,6x. Sie kann auch mit jedem anderen Okular mit 1,25" Anschluß verwendet werden. Die NIKON Barlowlinse verbessert die Bildfeldkorrektur und den Feldastigmatismus Ihrer Okulare. Besonderheiten sind ein Teflon Klemmring sowie die Art der Steckhülse welche über ein 1.25" Filtergewinde verfügt.
Die Steckhülse beginnt mit einem Durchmesser von nur 30,80 mm und erweitert sich erst nach 21 mm auf echte 1.25" Steckhülse. Beim Einsatz in einen 1.25" Zenitspiegel ist drauf zu Achten das Barlow, tiefer als 21 mm eingesteckt werden kann.
Freie Öffnung: 27mm
Baulänge: 72mm
Filtergewinde: M28,5 x 0,5
Vergütung: Voll Multivergütet
Gewicht: 90 gr.
Schaltet man die Barlow vor die NIKON Okulare muß praktisch nicht nachfokusiert werden. Subjektiv habe ich den Eindruck das die Barlow ne minimale verbesserung der chromatischen Korrektur durchführt. Da gestern das Seeing aber nicht so perfekt war wie in der Nacht zuvor , möchte ich hier erst noch weitere Tests durchführen
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/59328_1.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/59328_2.jpg
Link zur Grafik: http://bilder.apm-telescopes.de/images/artikel/73070_4.jpg
