Mist, da war jemand schneller ...
Aber dafür habe ich dieses:
------- snip -------
[] OpenGL now starts correctly (as in 6.0.0) for low-capability video cards.
[] Opening and closing the side panels no longer resizes the FOV!
[] Several significant fixes to Calendar event adding and display. Events are now correctly added and displayed in local times.
[] Added new buttons to set Calendar date to date shown in Starry Night view.
[] Saved presets now load correctly when saved with no file extension and selected from menu.
[] Printing in CSAP fixed. No longer centers pole.
[] Ambient Sounds fixed. Now turn on correctly on first try.
[] Correct object limiting magnitudes set for PGC catalog.
[] Fixed adding log entries to an item after deleting them.
[] Fixed significant leak (sometimes causing crash) when using HUD.
[] Fixed horizon pinning when in non-local orientations.
[] Fixed FOVs "(this chart only)" printing
[] Changing locations no longer changes object lock, including locks on random RA/Dec.
[] Preferences dialog no longer hidden under menu bar on some Intel Mac systems.
[] Several spelling mistakes corrected in locations database.
[] Cursor keys now move view correctly in non-local orientations.
[] Planet ordering in Find panel re-establishes correctly after find.
[] Asteroid diameters correctly reported. Were showing as 2x actual value.
[] 3DS models now load significantly faster.
[] 3DS models no longer look washed out after zooming in on sun.
[] Limit stars by distance and other fields like this now work correctly.
[] Prevented annoying redraw of Calendar panel when changing locations in space.
[] F8 in spaceship mode no longer used to show/hide the legend. Uses 's' to prevent conflict with toolbar.
[] Highlighted text now correctly turns white in events or lists.
[] Satellites can again be added orbiting the Moon.
------------ snip ---------
Bernd
