Stellarium 0.13.1 ist da !
PeterK
Hallo Sternenfreund,
wieder mal ein Update bei Stellarium.
The Stellarium development team after 3 months of development is proud to announce the first correcting release of Stellarium in series 0.13.x - version 0.13.1.
This release brings few new features and fixes:
- Added: Light layer for old_style landscapes
- Added: Auto-detect location via network lookup.
- Added: Seasonal rules for displaying constellations
- Added: Coordinates can be displayed as decimal degrees (LP: #1106743)
- Added: Support of multi-touch gestures on Windows 8 (LP: #1165754)
- Added: FOV on bottom bar can be displayed in DMS rather than fractional degrees (LP: #1361582)
- Added: Oculars plugins support eyepieces with permanent crosshairs (LP: #1364139)
- Added: Pointer Coordinates Plugin can displayed not only RA/Dec (J2000.0) (LP: #1365784, #1377995)
- Added: Angle Measure Plugin can measure positional angles to the horizon now (LP: #1208143)
- Added: Search tool can search position not only for RA/Dec (J2000.0) (LP: #1358706)
- Fixed: Galactic plane renamed to correct: Galactic equator (LP: #1367744)
- Fixed: Speed issues when computing lots of comets (LP: #1350418)
- Fixed: Spherical mirror distortion work correctly now (LP: #676260, #1338252)
- Fixed: Location coordinates on the bottom bar displayed correctly now (LP: #1357799)
- Fixed: Ecliptic coordinates for J2000.0 and grids diplayed correctly now (LP: #1366567, #1369166)
- Fixed: Rule for select a celestial objects (LP: #1357917)
- Fixed: Loading extra star catalogs (LP: #1329500, #1379241)
- Fixed: Creates spurious directory on startup (LP: #1357758)
- Fixed: Various GUI/rendering improvements (LP: #1380502, #1320065, #1338252, #1096050, #1376550, #1382689)
- Fixed: "missing disk in drive <whatever>" (LP: #1371183)
A huge thanks to our community whose contributions help to make Stellarium better!
LG+CS
Peter aus Wien
Danke Peter.
Gibt es bei Stellarium Mobile eigentlich die möglichkeit selber Objekte an zu legen oder PGC`s oder andere Kataloge ein zu spielen?
Mark
Leider lässt sich bei Ver. 13.1, 64bit nun nicht mehr ran- oder wegzoomen, wenn ich einen Kameraausschnitt gewählt habe, egal welchen! :-(
Nehme ich den Kameraausschnitt wieder weg, ist das Zoomen wieder möglich.
Kann man das korrigieren?
Mirko
Nabend.
Zumindest die MacOS Version hat einen üblen Käfer: Schaltet man auf Teleskopansicht und zurück kann man den Himmelsausschnitt nicht mehr mit dem Mauszeiger verschieben. ==> 0.13.1 runtergeworfen, 0.13.0 wieder drauf.
Nabend zusammen,
Auch ich habe das Problem, dass das Hin- und Herzoomen mit dem Mausrad und das Verschieben bei ausgewählter Kameraansicht nicht funktioniert. Egal, ob ich in den Einstellungen die Mausnavigation aktiviert habe oder nicht. Winx64, Stellarium 0.13.1 64bit.
Gruß Marcel
Moin zusammen!
Da sind so einige Bugs im Stellarium am Wandern... - Bevor man hier - einem im Übrigen an der Stellarium-Entwicklung völlig unbeteiligtem Astro-Forum - rumjammert, sollte man einen Blick auch diese Seite werfen: https://bugs.launchpad.net/stellarium
...und auch Bugs dort melden, wo sie behoben werden können. Auf A.de bestimmt nicht. ;)
