Rosetta spots its target
Inzwischen hat sich der Abstand auf 64 km verringert. Seit 10 Tagen wurden keine neuen Aufnahmen mit langer Brennweite (700 mm) mehr gezeigt, aber die täglichen Weitwinkelaufnahmen mit der NavCam zeigen mittlerweile auch immer mehr Detail:
Comet on 22 August 2014 - NavCam
Description: Rosetta navigation camera image taken on 22 August 2014 at about 64 km from comet 67P/Churyumov-Gerasimenko.
Credit: ESA/Rosetta/NAVCAM
Candidate Landing Sites
Philae candidate landing sites
Five candidate sites were identified on Comet 67P/Churyumov-Gerasimenko during the Landing Site Selection Group meeting held 23–24 August 2014. The approximate locations of the five regions are marked on these OSIRIS narrow-angle camera images taken on 16 August from a distance of about 100 km. The comet nucleus is about 4 km across.
The sites were assigned a letter from an original pre-selection of 10 possible sites identified A through J. The lettering scheme does not signify any ranking. Three sites (B, I and J) are located on the smaller of the two lobes of the comet and two sites (A and C) are located on the larger lobe.
Credits: ESA/Rosetta/MPS for OSIRIS Team MPS/UPD/LAM/IAA/SSO/INTA/UPM/DASP/IDA
Re: Candidate Landing Sites
Und hier sind die Textbeschreibungen der fünf Kandidaten:
A, which is located on the larger lobe, but in good view of the smaller lobe. The region is interesting because the terrain between the two lobes is likely the source of some outgassing. However, higher-resolution imaging is needed to study potential surface hazards such as small depressions and slopes, while the illumination conditions also need to be considered further.
B, which is located within the crater-like structure on the smaller lobe. This site is considered relatively safe for landing given the flat terrain, but illumination conditions may pose a problem when considering the longer-term science planning of the lander. Higher-resolution imaging will be used to assess the boulder hazards in more detail. In addition, the boulders are also thought to represent more recently processed material and therefore this site may not be as pristine as other sites.
C, which is located on the larger lobe of the comet. It hosts a range of surface features including some brighter material, depressions, cliffs, hills and smooth plains, but higher-resolution imaging is needed to assess the risk of some of these features. It is also well illuminated, which would benefit the long-term scientific planning for Philae.
I, which is located on the smaller lobe of the comet. It is a relatively flat area that may contain some fresh material, but higher-resolution imaging is needed to assess the extent of the rough terrain. The illumination conditions would also allow for longer-term science planning.
J, similar to site I, this site also offers interesting surface features and good illumination. It offers advantages for the CONSERT experiment compared with I, but higher-resolution imaging is needed to determine the details of the terrain, which shows some boulders and terracing.
Hallo Rosetta-Fans,
heute ist die ESA auf die Idee gekommen 4 Einzelbilder der NAVCAM zu veröffentlichen. Diese sind im Abstand von ca. 20 Minuten aufgenommen worden.
Das heißt der Komet ist sowohl näher gekommen und hat sich auch weitergedreht. Ein zusammen gebasteltes Bild hat die ESA nicht präsentiert. Nur dieses hie als 4er Composite ohne Randbearbeitung:
Link zur Grafik: http://blogs.esa.int/rosetta/files/2014/09/ESA_Rosetta_NAVCAM_20140831_montage.jpg
Nach einem kleinen Tipp auf FB konnte auch ich das Bild in 30 Sekunde zusammen setzen. Ein Thomas meinte ich solle mal den Microsoft ICE verwenden und es klappte auf anhieb.
Link zur Grafik: http://www.clearskyblog.de/wp-content/uploads/2014/09/ROS_CAM1_20140831A_stitch.jpg
Ich habs natürlich auch gleich in den Blog-Artikel eingetragen: Die Mission Rosetta und Philae
Viel Spaß weiterhin und ich bin froh das es neue Bilder gibt.
CS,
Stefan
Hier ist ein neues Bild mit der langen Linse: Comet on 5 September 2014
Jagged cliffs and prominent boulders are visible in this image taken by OSIRIS, Rosetta’s scientific imaging system, on 5 September 2014 from a distance of 62 kilometres from comet 67P/Churyumov-Gerasimenko. The left part of the image shows a side view of the comet’s 'body', while the right is the back of its 'head'. One pixel corresponds to 1.1 metres.
Und hier mal wieder der siamesische Zwilling in Gesamtansicht:
Comet on 10 September 2014 – NavCam
Four image NAVCAM mosaic of Comet 67P/Churyumov-Gerasimenko, using images taken on 10 September when Rosetta was 27.8 km from the comet.
Philae primary landing site
Announcement of the selected Rosetta primary landing site and a backup
‘J’ marks the spot for Rosetta’s lander
15 September 2014 - Rosetta’s lander Philae will target Site J, an intriguing region on Comet 67P/Churyumov–Gerasimenko that offers unique scientific potential, with hints of activity nearby, and minimum risk to the lander compared to the other candidate sites.
Site J is on the ‘head’ of the comet, an irregular shaped world that is just over 4 km across at its widest point. The decision to select Site J as the primary site was unanimous. The backup, Site C, is located on the ‘body’ of the comet.
The 100 kg lander is planned to reach the surface on 11 November, where it will perform indepth measurements to characterise the nucleus in situ, in a totally unprecedented way.
Philae's backup landing site
Credits: ESA/Rosetta/MPS for OSIRIS Team MPS/UPD/LAM/IAA/SSO/INTA/UPM/DASP/IDA / ESA–S. Corvaja, 2014
  • Announcement_of_the_selected_Rosetta_primary_landing_site_and_a_backup.jpg
Re: Philae primary landing site
Hier ist noch eine weitere Perspektive der primären Landungsstelle (J) und eine Übersicht aller in die nähere Auswahl gestellten Stellen. J liegt auf dem kleineren Kopfteil des Kometen. Die Backup Site C liegt auf dem größeren Körperteil.
Bislang vermittelten die Bilder vom Kern des Kometen ja eher den Eindruck eines gewöhnlichen Asteroiden ohne erkennbare Gas- und Staubemission. Bei dem hier nun gezeigten Bild kann man aber erkennen, was 67P/C-G zum Kometen macht. Die Gas- und Staubjets sind aber im Vergleich zur sonnenbeschienenen Oberfläche sehr zart und lichtschwach und werden erst durch Bildbearbeitung (Anhebung der Gradationskurve im Schwellenbereich) gut sichtbar.
Comet on 26 September – NavCam
The image shows the spectacular region of activity at the 'neck' of 67P/C-G. This is the product of ices sublimating and gases escaping from inside the comet, carrying streams of dust out into space.
„Ihr Sinn soll es sein, den Projektwissenschaftlern, die Jahre für die Entwicklung der Instrumente investiert haben, Zeit zu geben für Kalibration und Verifikation ihrer Daten. Und auch, damit sie einen Vorsprung haben, der sie davor schützt, dass irgendwer mit ihren Daten Wissenschaft betreibt und ihnen womöglich mit spektakulären Entdeckungen zuvorkommt.“
Das ist so ziemlich das absurdeste, was ich im Bereich der steuerfinazierten Wissenschaft bisher gelesen habe. Es geht doch hier nicht um einen Wettbewerb oder so etwas. Für die „Jahre, die diese Projektwissenschaftler investiert haben“, sind sie bezahlt worden, und zwar von uns allen.
Je eher die Daten veröffentlicht werden und je mehr Wissenschaftler mit der Auswertung befasst sind, desto eher gibt es Ergebnisse und umso besser werden diese ausfallen. Als Steuerzahler und somit Sponsoren dieser Mission sollten wir da eigentlich irgendwo protestieren.
Erstaunte Grüße
Maximilian
Hallo Thorsten,
lustig finde ich diesen Kommentar:
"Wir freuen uns bekanntgeben zu dürfen, dass Philae gelandet ist. Die bemerkenswerten Bilder können Sie in 6 Monaten sehen - wenn Sie Abonnent von Science sind..." :D
Burkhard
Jaja, so ähnlich.
(Und an Weihnachten erfahren wir, wer Fussball-Weltmeister geworden ist.
Kleiner Tipp: Spanien ist es diesmal nicht.)
Aber es besteht Hoffnung, dass die Philae-Betreiber
ihre Landeplatz-Panoramen zügig herausrücken.
Gruss
Thorsten
Und wenn euch für den Landeplatz ein besserer Name als "J" einfällt, dann könnt ihr das hier bis zum 22. Oktober vorschlagen:
Name Rosetta mission's landing site
A jury comprising members of the Philae Steering Committee will select the best name from the entries, and the winning proposer will be invited to follow the landing in person from ESA’s mission control centre in Darmstadt, Germany on 12 November.
Die bislang letzten veröffentlichten Detailaufnahmen der ausgewählten Landestelle mit der hochauflösenden Osiris Optik sind mittlerweile schon einen ganzen Monat alt.
Ja das ist die ESA-Politik, die könnten sich ein Beispiel an der PR-Strategie der NASA nehmen. Dort wird alles hochgejubelt (oft zurecht), hier kommt kaum was an die Öffentlichkeit. Speziell medienwirksame Bilder werden zurückgehalten, und das, obwohl Steuergelder diese Missionen finanzieren. In den USA ist die NASA verpflichtet, die Daten und Bilder der Öffentlichkeit zu präsentieren, weil diese sie bezahlt. Leider sieht man das in Europa anders.
Zitat von Burkard:
diese Gebirgslandschaft auf dem Kometen ist schon extrem beeindruckend!
Wobei ein Astronaut im Außeneinsatz sich dort zur Sicherheit wohl anseilen müsste: nicht wegen Absturzgefahr, sondern wegen der äußerst geringen Gravitation!
Die Schwerebeschleunigung beträgt dort nur etwa 0,0001 g und die Fluchtgeschwindigkeit etwa 1 m/s. Ein unbedachter Schritt ohne Seilsicherung würde dort reichen, und man entschwindet in den Raum!
Auch das noch: Komet stinkt zum Himmel
Wie riecht ein Komet? Seit Anfang August «erschnüffelt» ROSINA die Gase des Kometen Churyumov-Gerasimenko mit ihren zwei Massenspektrometern. Dabei erweisen sich die gemessenen chemischen Elemente in der Koma, der Gashülle um den Kometenkern, als ausserordentlich reichhaltig. «Das überrascht uns, weil der Komet noch über 400 Millionen Kilometer von der Sonne entfernt ist» sagt Kathrin Altwegg, ROSINA-Projektleiterin des Center for Space and Habitability (CSH) der Universität Bern. «Je näher der Komet zur Sonne kommt, desto mehr verdampft von seinem Eis, und umso stärker wird seine Ausgasung».
Der Komet «Chury» riecht offenbar ziemlich streng: Nach faulen Eiern, was auf Schwefelwasserstoff zurückzuführen ist, nach Pferdestall wegen Ammoniak und nach beissendem Formaldehyd. Diese Ausdünstung vermengt sich mit dem schwachen, bittermandelartigen Aroma des giftigen Cyanwasserstoffs, auch bekannt als Blausäure. Hinzu kommt noch Alkohol in Form von Methanol, ergänzt durch das essigähnliche Aroma von Schwefeldioxid und einem Hauch des süsslichen Dufts von Schwefelkohlenstoff: «Wenn wir all dies zusammennehmen, haben wir das Parfum des Kometen», sagt Altwegg.
